Design thread for the SA-43 Hammerhead Fighter (Space: Above and Beyond)
micahrogers
3,784
4,652
Shannon GA
Reactions: Awry_Chaos
Awry_Chaos
OKB-4155
Dec 22, 2020
1,228
1,572
95
49
Spokane, WA
Here is another update. I am starting to flesh out the position of the main wings and the primary exhausts for the engines. It will help act as a guide for the main fuselage and air intakes. Once I get those blocked out, I'll probably start adding loops, merging vertices and getting the overall mesh shaped up.
Awry_Chaos
OKB-4155
Dec 22, 2020
1,228
1,572
95
49
Spokane, WA
Did you try the file I posted? I got it to Render. See pic below. It could save you a lot of time and seems very accurate. :)
Yes, I got the file you posted and it opened up niceley in Blender. Thank you, it's a good find. The version I am going for comes from the actual screenshots of the CG model the used in the show. I'm attaching a couple pictures to show the difference between the model you found and the show's CG model.
As you can see the main differences are in the main "air intakes" on the top of the model and the "exhausts" at the back of the model.
Awry_Chaos
OKB-4155
Dec 22, 2020
1,228
1,572
95
49
Spokane, WA
Are you going to make a interior?
Yes, I'll be doing a cockpit interior. I was actually amazed by how big the cockpit interior of the Hammerhead is.
ByYourCommand.net has some excellent references of the cockpit:
That is the one thing Hollywood likes: big cockpit interiors, nice and roomy!
I also want to do two-seat and four-seat versions of the Hammerhead. Eventually there will be an ELINT/Electronics Warfare version, along with a Search-and-Rescue (SAR) version.
9,593
I see what you mean, the front engine intakes paint makes them look more different than they are, but the exhaust on this CAD model are way off. Most of the rest of the model is pretty accurate. I do hope that you will make leading edges on your model. Getting flowing lines and the compound curves of this model is quite a job. When I use a CAD model as reference, I usually tear 90% of it out, and use the over all shape to draw mu Control Points over, to get the right shape. I use pictures, like you do, to get the right shape. I exploded that Mesh a bit to show you that since most of the model is right, you could save a lot of time. With the parts separated, it would be easy to make proper exhausts. Stick with whatever method you are comfortable with. I do not know the capabilities of Blender, it's a bit unintuitive to me, so I stick to Rhino. This model will be a handful to make properly. Good luck! :)
Awry_Chaos
OKB-4155
Dec 22, 2020
1,228
1,572
95
49
Spokane, WA
Here's another update. The model's form is starting to take shape. I'm blocking in the major forms and big details, getting an overall shape to the model. So, far, so good. This update shows the progression of getting the top portion of the fuselage and the main air intakes. To do this I made a loop cut in the fuselage to mark the position of the main air intakes (see image: HH_0012.png) and then I extruded the four faces on the left side of the model to get the basic form you see in the images.
The next step will be to adjust this form to more closely match the reference. I may have to add a couple of edge loops in order to match the air intakes to the reference, keeping in mind that I'm just after the initial shape.
Awry_Chaos
OKB-4155
Dec 22, 2020
1,228
1,572
95
49
Spokane, WA
Blender is a capable program, but you are right, it's not that intuitive. I'm sure you've heard the saying: "There's the right way. The wrong way. And then there is the military way." The same applies to Blender. Blender tends to have its own way of doing things. Instead of going A, B, C, D, and E; with Blender it might end up going from A to B, then E to C, and then finally doing D.
