*NOTE* I HAVE NOT BUILT THIS MODEL!Now, my dears, I'm asking for a suggestion.
In back of part #3 I have a cut to join inside, but, at the moment, I couldn't find a piece to use for this, like the part #3-B. I'm thinking to use some little piece of paper to do this. Or the part is there, but I couldn't find the tamplate? Have someone a very appreciate help to me? Thanks, guys.
View attachment 151151 View attachment 151152
Doubling up on parts parts (like you had shown). It makes sense to do such. It looks like it would add strength to those areas.Are you doubling some of those parts, and making the tabs then line up on the same plane? Like in the pic below? It looks like that, could be an illusion, but it a damned good idea, if you are, or if you aren't. An alternative to cutting off tabs, cut off the tabs, and glue that part to the part with tabs. It would make for an incredibly sturdy model too. I have done this when I have messed up parts, rather than trash a model. I think they are almost always fixable. This is coming out excellently!!
I just looked through the instructions. To me, it looks like you just edge glue the seam together (I would suggest using a thin piece of paper to give it a bit of strength). It looks like there are other interior parts (I think parts 8-11) that will but up to that part.
Best of luck with it!
