Fiat 508 "Balilla"
9,548
Tonino, I am at a loss of words!! It's so strange the way this all came together. Thank you for letting me be a very small part of it. I have started working on a rudimentary frame. The way this car was designed, your body will set right on it. :)
Tonino
791
1,775
83
61
Republic of San Marino
www.facebook.com
John, you wasn't a small part of it; you was the one who caused this to happen! ;)
I had just started another BIG project (Castel del Monte) but - after having seen the Balilla - I suddendly put it in pause to jump straight in this one (it was love at first sight!!!) :violin:
So I have to say tank to you for having found this little rough diamond waiting to be cut :D
Reactions: DanBKing
9,548
Tonino
791
1,775
83
61
www.facebook.com
I had a little incident on my build. I was so depressed with it that I was very close to trash my work in progress and start over from the beginning... But let's go in order.
This is the heavy cardboard piece that closes the ceiling giving shape to the roof of the car.
The original piece had no color, it was not printed. I decided to paint it because it's clearly visible from the windows.
...and here is the problem. The upper bodywork piece doesn't fit with the existing sidewalls. There is more than a millimeter at every side in the rear wall and other gaps in the front part as you see.
I redraw the piece leaving something more than needed to be able to trim the excess once the part is in place (melius abundare...)
Redrawn the ceiling with the new shape.
Prepared the "glass" pieces for windshield and rear window.
Prepared an inner sheet with interior colour to be glued to the underside of the ceiling.
The parts are now glued togheter.
I cut the central section (not visible under the heavy cardboard seen above) to concentrate my attention to the windows (I prefer to glue only one window at a time).
Prior to place the ceiling I glued the rearview mirror to the inside. Nice detail!
Now this edge is not flush with the side wall. I tried to cut the excess with scissors and ... TRAGEDY!!!!! The scissor blades scratched away big sections of ink from the parts.
Conclusion: NEVER USE LASER PRINTER FOR YOUR CARDMODELS ! ! ! ! I swear I'll not do it nevermore!!!
I choose laser print to have a more "glossy" look, I thought it would be better for a car.
But the laser pigment has very low "grip" on the paper. Only touching it with fingers changed the color of the bodywork.
Now the scissors have produced big white scratches.
I have ruined my car. I tried to retouch the scratches with a felt tip pen but the result is a disaster!!!
...continues...
Tonino
791
1,775
83
61
www.facebook.com
... I waited one day until I cooled off...
Now I can think to some walkaround.
I printed other copies of the side walls on thin paper (photocopy sheets) to add only little thickness
Carefully placed it over the ruin
Much better. See how the color of the old part, under the new, was changed only touching the model with fingers (see on the left).
Laser print is not reliable at all.
Now I can place the engine hood and start to think about the radiator grille...
Tonino
791
1,775
83
61
www.facebook.com
Yes RB, I considered it. Really my first thought was to cut the louver and fold outwards the paper to give it a perfect look but, after my recent ink problems... I gave up. I'm afraid I'm going to have color falling away from all the hood if I cut it the way I was planning to do.
Your question, however, re-ignited my interest on this part of the car so I wanna give it a try. I'm going to print a copy of hood side walls on thin paper, I'll print also some red on the rear side (so I won't have to use pen on it). I'll cut and fold it... and let's see what happens...
9,548
I have found a frame and under carriage for this car. It will take me around two probably much more, days to make it "construct-able", but it's all there. Keep working on what you are doing, if you body doesn't drop right down on it, it will only take a few cut on the flat bottom to make it fit. :)
Tonino
791
1,775
83
61
www.facebook.com
:) Thanks John, I'm very happy to hear it and I'm very curious to see how it will came out.
Anyway, to be completely honest :angelic: I'm not sure I like very much the idea of cutting away the body of my model from the frame.
I'm afraid the operation couldn't be done without some danger for the upper structures.
I'll have to consider it well. It would be better to do some fitting tests before trying to put the hands on the body.
If the frame is detailed enough - I'm writing as I'm thinking - it could be presented as a stand-alone subject side by side with the completed car.
Something like the situation depicted in one of the photos in your previous post:
This solution - however - should require a complete - and detailed - engine... Is your 3D model complete of engine?
And - another important question - do you have also the wheels? The ones included in this model are a little too "square" in my opinion. It would be nice to find a possible alternative.
9,548
Actually, I think you will be able to cut the frame up and glue it to the bottom! :)
Reactions: Tonino
9,548
You Body work is fine, we'll just adjust what is necessary for this to bolt to the frame, and YES, You and I will have created a whole new model!! :)
Tonino
791
1,775
83
61
www.facebook.com
@Rhaven Blaack this is for you!
After all I couldn't ignore your suggestion...
I printed a copy of the hood on thin paper
Really this is a first try.
Then I noticed slots were not aligned and misplaced.
I redraw them and printed again.
I also printed red the backside to avoid some white surface to be visible from rear.
This looks much better than the black printed louver.
A touch of black pen to the underside
And this is the new hood side in place!
:D
9,548
The louvers knock it right out of the ball park! :)
Reactions: Tonino
9,832
This is the great value of a place like this! I wouldn't ever placed my blade on that hood without RB's words.
... ... ... and, after all, I wouldn't ever started this thread without a certain gift I received... ;)
I am glad that I could be of help to you. thumbsup
I really like how this is turning out!
Reactions: Tonino
