How do you "paint" the edges of your parts?
  • Total voters
    179
mbauer
Cardstock Model designer
Jan 31, 2006
18
66
Nikiski, Alaska
At present use felt tip pens.
Used watercolors in the past, they work great to match but a couple of times used to much, paper got wet and warped. Never heard of the dry-brush technique, will try it to see if it will work.
Used pastels as well, only issue there is when the little color balls fall off and then it is easy to smear the color on the paper.
Colored pencils kept "flaring" the edge of the paper, making the joint more noticeable than if just leaving it white.
Still testing the waters, thinking it might worth the effort to re-try the watercolors using the dry brush technique. Thank you for posting it!
Mike
Reactions: Rhaven Blaack
9,857
Mike
I would like to see your progress and how the dry brush technique works for you!
cdwheatley
48
27
21
Waterlooville, Hampshire, England
I use watercolour pencils. I wet a brush, not too much, then use it to lift some of the colour from the tip of the pencil and apply it to the edge of the card. I have a box of 36 different coloured pencils at the moment and I've never failed to get a good colour match yet.
SCEtoAux
175
22
18
USA
I use Prang brand colored pencils for the most part. You can dip them quickly in some water or use your tongue to wet them then apply the color to the cut edge. You can blend the colors to try and match the adjacent color. Sometimes just using a shade of grey works too. It helps to use something like a bone folder to compress the cut edge before you color. That helps to keep the fuzzies to a minimum and gets rid of the annoying ridge that sometimes shows up after cutting.
Prismacolor pencils and some oil pastels are used sometimes, too. I always do the edging with the printing facing away from me so when the pencil or pastel slips it will not mar the graphics.
Capt.Jack
3
3
Röderland Germany
Hello,
I m using water colours thats my favorite. Sometimes using "Pastelkreide " . I dont know the exat word in english ( Sorry) So i do the weathering at my AT-AT.
Gregor
9,551
I try to make sure there are not edges. Eliminate all tabs, use strips, then the surfaces will line up and this will become a non issue.
Reactions: lyter1958
Martinus
Ireland
Someone used the technique you describe, zathros, (and some coloured pencils) to great effect when building my Ebon Hawk model. I'll have to try it with my next model.
bigpetr
Designer/Master Modeler
Jan 27, 2016
922
1,461
Czech Republic
I use watercolours.
Technique Zanthros described is best and I prefer it whenever possible. But when you need to glue edges in sharp angle than edges are visible even with this technique. So I color the edges even with this technique just to be sure :)
Do you guys fix watercolour colored edge model with some lacquer? Is it necessary?
Reactions: zathros
9,551
Try to find a Pigment Ink, it will not run. You can actually take your ink cartridge out of your printer and scavenge some ink from there. The pain as most Hobby shops have colors that are very close if not exact, and I have used a pin to put little dabs of pain, then gently smear it where I need it. I remember when I used to build commercial plastic model planes. I always liked the Piper Warriors, and back in the '70's, there was a model of one. When I began to fly for real, I was shocked to see how bumpy these planes look. The Winter is worse as the plane shrinks, and looks kind of crumpled. The same plane in the Summer looks all stretched out, it is the same way with steel ships, some destroyers really look beat up, but it is just the elastomeric properties of these crafts, sometimes perfection and realism don't match up. :)
