Having a run at the Legal01 Re-envisioned Saturn V Mark III
9,548
When I worked at Sikorsky Aircraft, whenever a critical parts was made, that part was put in an offsite facility, deep in the ground somewhere, to act as a reference copy. This model looks to be of that quality, though I do not think it should be buried! :)
SonOfAGun2501
Esteemed Member Extroadinaire
May 11, 2014
324
642
83
45
Ichikawadaimon, Japan
Thank you for the kind words. Glad I read through to the end though I was just thinking where the shovel was. :)
Reactions: DanBKing
SonOfAGun2501
May 11, 2014
324
642
83
45
Here is the current progress as well as asking for help if someone can find out or knows about the following. I am trying to figure out how to line up the parts for the inside of the tank I can't find any relevant information on where the lines connect as far as the outside markings. If anyone has any info or could point me in the right direction, I would be very greatful.
20150921_175241.jpg 20150921_175252.jpg 20150921_175812.jpg 20150921_180422.jpg 20150921_194753.jpg
Reactions: Tonino
SonOfAGun2501
May 11, 2014
324
642
83
45
The inside parts fit against the exterior parts so where the outside joins so does the inner parts. Hope that helps
I get that aspect, I am more interested in how they line up with the outside of the rocket. For example, part 10 goes in section A, B. or B,C, etc. If I can figure out one then the rest will fall into place.
9,548
Coming along nicely! Your getting the best Legal help possible, and it's pro boner, sorry, meant bono! Freudian slip. Maybe a slip of the jung! (Freud wore dresses!) :biggrin:
url
SonOfAGun2501
May 11, 2014
324
642
83
45
Sadly, I can only upload 10 pics at a time. Here is the last one and the top of the dome. ;) The dome was a nice build went together really smoothly. All the parts fit together perfectly. Down to the base former.20150922_105734.jpg20150921_175241.jpg 20150921_175252.jpg 20150921_175812.jpg 20150921_180422.jpg 20150921_201453.jpg 20150921_213035.jpg 20150921_215114.jpg 20150921_223054.jpg 20150921_224556.jpg
You will only need to cut holes in two of the dome sections. They should be one panel apart from each other.
