Having a run at the Legal01 Re-envisioned Saturn V Mark III
SonOfAGun2501
Esteemed Member Extroadinaire
Here comes another update for you. Finished the first connecting line so, I thought I would share the progress. This piece fits pretty well over all, you may need to do a little trimming but for me, the first one was pretty much dead on. This was also a fun little build.
20150915_164603.jpg 20150915_170505.jpg 20150915_170641.jpg 20150915_170801.jpg 20150915_170926.jpg 20150915_171058.jpg 20150915_181019.jpg 20150915_181650.jpg 20150916_202402.jpg 20150916_203021.jpg
When I worked at Sikorsky Aircraft, whenever a critical parts was made, that part was put in an offsite facility, deep in the ground somewhere, to act as a reference copy. This model looks to be of that quality, though I do not think it should be buried! :)
SonOfAGun2501
Thank you for the kind words. Glad I read through to the end though I was just thinking where the shovel was. :)
SonOfAGun2501
Here is the current progress as well as asking for help if someone can find out or knows about the following. I am trying to figure out how to line up the parts for the inside of the tank I can't find any relevant information on where the lines connect as far as the outside markings. If anyone has any info or could point me in the right direction, I would be very greatful.
20150921_175241.jpg 20150921_175252.jpg 20150921_175812.jpg 20150921_180422.jpg 20150921_194753.jpg
legal01
The inside parts fit against the exterior parts so where the outside joins so does the inner parts. Hope that helps
SonOfAGun2501
I get that aspect, I am more interested in how they line up with the outside of the rocket. For example, part 10 goes in section A, B. or B,C, etc. If I can figure out one then the rest will fall into place.
Coming along nicely! Your getting the best Legal help possible, and it's pro boner, sorry, meant bono! Freudian slip. Maybe a slip of the jung! (Freud wore dresses!) :biggrin:
url
SonOfAGun2501
Sadly, I can only upload 10 pics at a time. Here is the last one and the top of the dome. ;) The dome was a nice build went together really smoothly. All the parts fit together perfectly. Down to the base former.20150922_105734.jpg20150921_175241.jpg 20150921_175252.jpg 20150921_175812.jpg 20150921_180422.jpg 20150921_201453.jpg 20150921_213035.jpg 20150921_215114.jpg 20150921_223054.jpg 20150921_224556.jpg
You will only need to cut holes in two of the dome sections. They should be one panel apart from each other.
SonOfAGun2501
Here is the rest of the dome and the attaching to the 1st stage. The pipes did not line up 100% but I adjusted as best as possible. Still happy with the final result which does look really good.
20150921_232548.jpg 20150921_234245.jpg 20150921_234931.jpg 20150921_235232.jpg 20150921_235501.jpg 20150922_143623.jpg 20150922_150217.jpg 20150922_152544.jpg 20150922_152821.jpg 20150922_153010.jpg
