Having a run at the Legal01 Re-envisioned Saturn V Mark III
SonOfAGun2501
Esteemed Member Extroadinaire
Thanks everyone. There is still so much to do but the cylindrical parts go together pretty quick. Really looking forward to seeing the finished result. Thanks again everyone for all the support. Truly appreciated.
Tonino
Cannot wait to see what you'll do when you'll have completed the third stage. With your detail care I should expect an UHU scaled-down lunar module. At least it has foldable landing gear. Should be no problem to put it inside ;)
SonOfAGun2501
And here I was thinking I'd complete the project before the end of the year.
SonOfAGun2501
Here are the following two sections.
20150830_190936.jpg 20150830_191857.jpg 20150831_175515.jpg 20150903_203046.jpg 20150903_203059.jpg 20150903_203109.jpg 20150903_203121.jpg 20150903_203144.jpg
Only difference for the last white section is there is no ring former inside. It will go into the last part of the structure that's why there is a different joiner at the top. The alignment for all the parts will follow the system tunnel markings.
