SonOfAGun2501
Esteemed Member Extroadinaire
Next up I will be starting the rest of stage one. Can't decide if I should put the engines on now or after I finish the first stage. Thoughts anyone?
Yeah, that's what I was thinking as well. Also, in the future I probably would put the fins on after building the rest of stage one.I would suggest building stage one and attaching first and then placing the engines, with the engines in the way you don't have a flat base to push against when joining the parts. Once stage one complete then add the engines.
That may be the best quote I have ever heard."Hindsight is an exact science ...."
I know right. Damn, oh well back to square one.Oh dear, you will just have to start from scratch again then!
Great suggestion thanks.Don't forget to insert some pieces of rolled up paper into the tubes to add strength and rigidity.
Very happy to have you back and up to date.I don't know why sometimes system stops notifying me new posts in my followed threads.
I was loosing a lot of work here! Two full pages of new pieces I didn't see at all.
Great work: now I'm aligned with actual status of the build!
Well, no. Not until now. But definitely a suggestion worth thinking about. For my test build, I am just seeing how the pieces all fit together. When I do my build, I think I will shrink the paper down to B5 and make a smaller model. When I do, this idea will be really useful.Have you ever considered making a tube, a strong one, the same size as the rocket tubes, then filling it with construction foam, lining the interior tube with Vaseline to act as a releasing agent. You could then cut slices and stick them in the tunes, with a wooden dowel in between, using less foam, and making the rockets sure to hold their shape.
