Having a run at the Legal01 Re-envisioned Saturn V Mark III
SonOfAGun2501
Esteemed Member Extroadinaire
The top section of the fairings is difficult. Each one I tried to attach in a different way and all the results varied. They are a very tight fit regardless. This particular step will take a lot of time and patience that is the best advice I have on this. The end result looks really good though.
20150806_111942.jpg 20150806_112557.jpg 20150806_112607.jpg 20150806_112832.jpg 20150806_111816.jpg 20150806_113127.jpg 20150806_113139.jpg 20150806_122525.jpg
SonOfAGun2501
Now comes the fun part of more small tubes. If I haven't screwed up the lay out too badly, then these should all fit into place quite nicely. Once everything is in place, just do it again 3 more times and you should be mostly done with the thrust structure. Do be careful though, on the plans part number 30 the last one there is a bit of an error. For now just print out an extra and that should cover you for the rest of the build. thumbsup
20150807_101209.jpg 20150807_110353.jpg 20150807_110812.jpg 20150807_111003.jpg 20150807_111426.jpg 20150807_112631.jpg 20150807_112933.jpg 20150807_114835.jpg 20150807_115041.jpg 20150807_115044.jpg
The amount of work, coupled with the amazing consistency is quite impressive. The engines all look alike, and that's a very good thing. Incredible actually. :)
SonOfAGun2501
Thanks so much for all the positive feed back everyone. You guys are all keeping me motivated. The finishing touches are going into the thrust structure presently. More photos coming soon.
